WIDE TIRE KIT QUESTION
Old 11-04-2006 | 01:25 AM
MAX EVO's Avatar
MAX EVO
Default WIDE TIRE KIT QUESTION
I plan on getting the 180 Wide tire kit.However I want to use a Metzler not the S-E Dunlop.Will the dealership order the Metz and switch out the tires???Or do I have to buy the Metz and eat the Dunlop?
Old 11-04-2006 | 01:44 AM
veniculum's Avatar
veniculum
Default RE: WIDE TIRE KIT QUESTION
Good luck man....somehow I doubt highly that a dealer will give you that option. The kit specifically includes the SE dunlop.
In my opinion, why don't you try the dunlop. I have the 180 SE and I like it alot. It seems to handle fine for me. Then if you don't like that, get the metz.
If you are able to find a dealer that will do that for you...please let me know who it was. I'll buy my next bike from them
Todd
Old 11-04-2006 | 02:06 AM
clayman's Avatar
clayman
Just put the metz on, ive got a 180 on mine and didnt but any hd wide tire kit on.
Old 11-04-2006 | 03:18 AM
stix68's Avatar
stix68
Ive been check'n the Metz web site out, which specific tyre do metzeler make to suit. I see a lot of 17 inch rear 180/55 tyres. I don't see a 60 or 70 profile. Wouldn't the 55 profile really mess with speedo calibrations. Standard profile is 70 the SE tyre is 60. Can anyone be more specific with their Metzeler tyre choice.
Old 11-04-2006 | 04:00 AM
SKT's Avatar
SKT
Never hurts to ask, worst they will say is no.
Old 11-04-2006 | 09:56 AM
mikeurig's Avatar
mikeurig
If you go here:
http://www.ironpony.com/ironponydire...CTS&?s=o&k=264
you can click on different manufactures and check the sizes, like you said there are a lot of 180/55/17 tires but not 180/60/17. I'll ask that site what would happen if someone used a 55 instead of a 60.
Old 11-04-2006 | 10:06 AM
mikeurig's Avatar
mikeurig
Here's a tire calculator to determine your speedo question:
http://www.miata.net/garage/tirecalc.html
or here
http://www.1010tires.com/TireSizeCalculator.asp
Smaller size '55' instead of '60' will read a slower mph by about 2.8%
Old 11-04-2006 | 11:07 AM
stubby's Avatar
stubby
I've been looking around at same thing. My dealer said "No", but I have read posts where dealer did install non HD parts. I think it is up to the specific dealer. It is reported that metzlers in the same size run thinner then other tires. The 160 looks thin and metzler has not made a 170, yet. A 180 will probable fit newer dynas with minimal effort. Since the wide tire kit uses the same wheel with what probably is different spacers and a part you can buy from Harley that holds wiring out of way, most of the money spent on wide tire kit is for the tire. Looking at picture of dunlop screaming eagle tire it looks respectable with very similar tread pattern to metler and avon.
Look around for indy Harley shops or call a couple different dealers. Good luck.
Old 11-04-2006 | 11:41 AM
mikeurig's Avatar
mikeurig
Metzler does make an ME880 170/60VR/17 rear tire, Part# 11011943 $138.99
http://www.ironpony.com/ironponydire...EET%20PRODUCTS
Old 11-04-2006 | 12:58 PM
MAX EVO's Avatar
MAX EVO
Do you need the the kit or can you just buy the 180 and put it on?What I am going to do is get the HogPro Lemans wheels in blk front and rear and the matching rotors and sprocket.What size wheels do I order from them for the Bob they have different sizes? thx
Quick Reply: WIDE TIRE KIT QUESTION
