accessory wiring
Old 06-20-2011 | 09:51 PM
Rudy046's Avatar
Rudy046
Default accessory wiring
Hi, Gang.
Has anyone hardwired or found an accessory plug to charge their iPod or Garmin to their electrical system?
If so, would you have the link or directions to do this?
Fat Bob 2011
Thanks you in advance,
Rudy
Old 06-20-2011 | 10:40 PM
bberck's Avatar
bberck
I used one like this plugged to my battery tender plug on my Dyna
http://cgi.ebay.com/ebaymotors/BATTE...Q5fAccessories
Old 06-21-2011 | 12:59 AM
HemiOrange's Avatar
HemiOrange
I just mounted a cig lighter under the seat. I have an adapter for my Battery Tender and plug it in here. If I need 12V power, I have it.
Old 06-21-2011 | 01:56 AM
hart11b's Avatar
hart11b
Default Burns moto
I used this one on my dirt bike for USB charging. It attached right to the battery and would charge my IPhone when riding and can be used for GPS also. They make a Powerlet plug for the cigarette lighter type applications as well.
It's worked great so far (2 months), no issues.
Old 06-21-2011 | 11:24 AM
JRK5892's Avatar
JRK5892
i have a sig plug as well,. and a min power line, my remote line for my stereo to turn it on and off runs off the speedo light
Old 06-21-2011 | 01:42 PM
pontiac69's Avatar
pontiac69
Originally Posted by Rudy046
Hi, Gang.
Fat Bob 2011
Rudy
There should be a plug under your seat that looks like ( see pic ). It is the accessory plug and only works with the ign on. Turns off when ignition is off so nothing drains the battery. There is also a single connector that is battery positive.
Attached Thumbnails accessory wiring-accessory-plug-final.jpg   accessory wiring-p3160095-1.jpg
Old 06-21-2011 | 05:20 PM
NeverEnoughToys's Avatar
NeverEnoughToys
+1. That's what I did. HD also makes a y connector for that if you want to connect two items to it. Some people splice and solder, I always use some kind of connector.
If possible, I'd recommend using the accessory connector rather than the battery connection. Otherwise, you may end up with a fully charged GPS and a dead bike one day. I know I would because I'd always forget to unplug it.
Musashi (09-16-2022)
Old 06-23-2011 | 08:21 AM
Rudy046's Avatar
Rudy046
Default 70270-04
... would the acc y-connector be part # 70270-04 for $15.95
Old 06-23-2011 | 09:50 AM
pontiac69's Avatar
pontiac69
that part is for teh battery positive y connector. it has 4 single wires connected together. i used part number70264-94A . this gives you 1 in and 2 accessories out. this gives you power when the ignition is in the on position and turns off when you turn the bike off.
Attached Thumbnails accessory wiring-70270_04_-dyna-plug-2.jpg   accessory wiring-p3160098.jpg
Old 06-25-2011 | 07:35 PM
NeverEnoughToys
Confirmed. That is the one I used as well. I mistakenly ordered that battery positive y the first time and was a bit miffed at not checking the number twice.
wingman1800
02-09-2020 02:10 PM
gauthier613
08-06-2013 01:41 PM
gpp
02-07-2011 12:19 PM
bobby84_00
Electrical/Lighting/Alarm
01-09-2011 04:23 AM
yodal
08-02-2006 08:59 PM
Quick Reply: accessory wiring
