Front brake switch acting up
The brake switch works the brake lights correct but the dash light stays on and the tail led ( light up dim) for the plate when you shut down the bike . So I take the front switch assembly apart to investigate and I find that the switch works the brake lights when you apply the brake but like I said the other two lights stay on when you shut down the bike. then by wiggling the front brake lever makes the lights go out.
So if I stick a piece of cardboard in the lever to just engage the front brake switch slightly , the two lights (dash and rear license) go out and it's normal.
I figure I must of ruined the front brake switch when I removed the lever.
I have just purchased a new front brake switch on Ebay and have to wait a few days for it.
I have the battery tender on it and it is fully charged and the 2 lights that came on were little with light draw. They go out with a shim in the lever appling slight front brake pressure so I'm 90% sure it's the switch.
Is is normal to have your front brake switch go bad by just removing the lever?
Hi,
The end broke when sliding the new lever on mine,this made the brake light on all the time. So I fitted a very small screw inside the little pin so that it was back to the correct length.
I had a very small drill that I used to make a pilot hole before I fitted the screw.
The cost of a new pin was ridiculously high so I improvised with a very small screw.
Jeff
Jeff
OK different than my situation. my switch works the lights during normal operation.
This morning it was fine and still is.
I did give the bike a good soaking yesterday but just used the hose and sponge bath.
Maybe I got some water in the wrong spot.
Well I have a new switch comming anyway and hope to just put it on the shelf.
The bike has 3 year warranty but I hate bringing it in as I need it.
Daily rider means figuring it out and ride on.
Another day brings joy here. I'll be keeping my eye on it for sure during the next rain.
newmanb138
2014-2023 Touring Models
04-27-2017 08:15 AM
xxINKxx
01-21-2013 11:01 AM
