Oil leak from left side center, possibly the mainshaft seal?
yep, found oil under my bike. it is coming from higher up than the drain plugs, more like the shaft seal or primary somewhere. Was riding and didn't notice any mechanical problems. Not even sure which oil it is yet, but it looks clean.
I took a pic with my phone, crappy resolution and after I wiped around with a rag, but maybe it might help to see the problem.
Last year the alternator grenaded and the Inner Primary bearing, race and seal were replaced when all that was apart. I would be tempted to replace that seal again, but the front of the pulley is not oily so I doubt it is a problem.
It really doesn't look like a shifter shaft leaking, more like it is coming from behind the drive pulley because the tranny behind the final drive pulley seems the most wet.
Any suggestions?
Any suggestions?
Well, I seem to be the only one interested in this problem. I am going to post again to show what I have found, just to close the circle a bit...
After progressively upping the attempt to remove the sprocket nut, I have gotten behind the sprocket. I first acquired the correct HD tool for the job and promptly grenaded my 1/2" drive ratchet using a 1/2 to 3/4 adapter and a long piece of pipe. my bad.
I then went and bought the proper 3/4" breaker bar and, with the pipe, couldn't budge it.
The next try was to center punch the nut in 2 places and drill into the nut with a 7/32" bit. Then I simply took a punch and split the nut.
The sprocket slid off like it was buttered.
And here is the seal that was leaking:
If a seal leaks, there has to be a reason, right?
yep, the bearing is hosed. adding oil as it leaked out would have been a catastrophic decision.
I ordered the parts and I hope they will be here tomorrow.
If it's a 6 speed that bearing is a double row bearing and I'm thinking you will have to take the trans apart to replace it .
It is #7 in the pic and you can see in the other pic that the inner race
of the inner row of bearings is pressed on the shaft .
Mine had metal shavings all thru the trams so it had to come apart
to clean everything
to clean everything
to clean everything
to clean everything
I am sure that would be possible because it is the basic process described in the service manual, but how hard would it be to install the gear back into the case, without wrecking the mainshaft and the new bearing?
I am positive it wasn't leaking, but for the few dollars it costs, I did it anyway.
Both the seal and the inner bearing were installed new last August after I got home from Sturgis and the rivets came loose on the alternator rotor and took out the stator.
