New Tire Needed?
New Tire Needed?
Just wanted some opinions on:
1. Do I need a new rear tire? If so, how soon?
2. Why good tread in some areas, and not on others?
3. I would like to go wider, but I'm still confused on whether to go to a 170 or 180. And if so, who makes those tires.
This is the original tire with about 10k on it. I realize that's about normal, but just trying to keep it on as long as possible.
I've attached 3 pics from 3 different views of my tire to give an idea of the different tread patches.
yes you need new tires. could be a number of reasons why some areas wore out faster then others. bottom line you need new tires. try the SE 180 (tire on the new wide glide) you won't need the wide tire kit, just make sure your turn signal wires are tucked away. If you want a bit more performance/grip go with the metzler 170 (they don't make a 180 for the stock rim)
And it's a good thing you know everything about bikes, so that I can ask these questions!
I'm not trying to imply I don't know when to replace tires. I'm simply asking what the thoughts are on if it can go longer. There is NO issue with the tire itself, it's just the tread is worn in the middle. And the only danger that imposes is in the rain - and when it rains, I take the cage. And thankfully I haven't gotten stuck in much rain.
If you value your life, you wouldn't need to ask when you should change your tire. You should be able to look at that and say "dang, that's bad. Better order new tires since I only have two of them between me and the road."
And I don't claim to know everything about motorcycles but I do have enough common sense to know when a tire change is necessary without looking for validation on an internet forum.
