Hit a speed bump and bike died, ideas?
Hey all, I was out riding last night and hit a gnarly speed bump. Bike cut out almost instantly. All the electronics still work, bike still turns over but will not fire. My first thought was the shock had triggered the fuel shut off switch (tip mode). Waitied 15 mins and bike still would not start. Disconnected battery, still nothing. Reset fuel shut off device (inside electrical box), still nothing. Ended up getting it towed home.
I've got it on the trickle charger now as I pretty much drained the battery trying to start the bike but I plan on screwing with it this afternoon. Anyone have a similar experience? Any ideas as to what is going on? I'm almost certain its something electrical in but I'm not sure where to start.
did you check to see if you have spark? if not i would check the plug for the ecm and also check the coil feed line.
if you have spark then check the wiring for the fuel pump or possibly fuses/relay's
have you seen this thread?
https://www.hdforums.com/forum/dyna-...lp-please.html
so i would check the ground on the battery and engine first and then move on to the relay's
Something has definitely jarred loose.
Ok guys, I checked fuses, relays, and grounds to and from the battery. All good. I also checked and cleaned the ECM connection. A few pins were quite dirty and looked dark brown/black, almost like they had gotten too hot.
I checked DTCs and got three codes, none of which I was expecting seeing that I thought my problem was no spark. Here are the codes:
P0261 - Front injector open/low
P0263 - rear injector open/low
U1097 - loss of speedo serial data to ECM
Any ideas? I just went and bought a multimeter to begin checking sensors and whatnots. I've never used one before and am somewhat lost, so if anyone could explain how I would go about checking ohms at the coil/crank position senor I would greatly appreciate it.
Update: I checked the coil with the multimeter and the ohms check out. Still not sure how to check the coil lead.
