FXD exhaust question
I am looking for replacement factory exhaust for my 2003 Super Glide and I am trying to find out if newer factory exhaust will fit. I have found a set from a 2009 FXD. I know it has O2 bungs but those can be plugged. Other than that, are there any other differences that would prevent me from using them?
I'd first check for aftermarket fitment. If the same part number that fits the '03 also fits the '09, then you have a direct replacement, even if using stock pipes. On the other hand, even if they aren't listed as fitting, as 8541hog mentioned, the mounts may just be different. Some flatbar and a few drilled holes should be able to make them fit.
The problem with the current stock header pipes is they rusted out where the muffler slips on. The Screaming Eagle mufflers and the covers on the header pipes were damaged by the tires and frame on the bicycle I hit at 80mph. Luckily there was no rider on the bike, it fell off of the back of an SUV.
I just noticed your pic of your bike with fatbob pipes, is there any clearance issues for the oil cap, hard to tell in the pi
I have no issues with it, but you would probably want a glove or towel or something, but then I wanted that with the stock pipes...
