fender fit?
I do know that the '07 Dyna FXD has a 8.25" wide rear fender.
I just bought a Jesse James 8.5" wide roller rear fender, but had to narrow it and re-radius it to fit. If you can find one that fits between the struts, you are way ahead. I just wanted one with a smooth rounded contour instead of the the stock stepped contour of the Dyna.
Buying stock fenders just lists the direct replacements, even if a simple hole can be drilled or one of them not used. Too often they will fit without any mods whatsoever. Just be aware that softails and Dynas are two different bikes, so on and so forth.
You are best off to use some of the tried and used fenders as posted here. A drill, too often, isn't enough to make them fit right.
Bean might have the solution for you, part number and all!
