What is this and why is it covered in oil?
dude, there are no oil lines coming off of that thing....It's a voltage regulator and a motor mount pictured. The mount gets oil on it 90% of the time during an oil change. Should get cleaned thoroughly afterwards but often doesn't. The film left over attracts dirt and road grime..which is abundant in that area, especially if you aren't running a front fender. Spray it off with some brake parts cleaner/carb spray/electrical parts cleaner or any other non combustible aerosol cleaner when it's cool to the touch. Also the clutch cable can sometimes draw oil up inside of it, thats the lowest spot for the routing of the cable and it too can sometimes collect some oil in that area..Neither is a huge dilemma unless it's actually leaking onto the ground in puddles. Clean it, check your levels, adjust as neccessary, move on with life
For the record, that rubber thing below that has the two large allen head bolts mounted vertically is the front isolator.
Thank you all!!
Yeah no oil cooler on this yet. I've been thinking of getting one.
I cleaned it all up last night and will watch it. I didn't realize that's where the motor mount was. That's what is covered in oil, not the regulator. The rubber around it looks pretty chewed up too.
Thanks again!
Thanks again!
