Bassani Road Rage Pipes
Road Rage Pipe
I have the original road rage...I guess the road rage 2 is the new longer version of the original. Would be nice to be further away away from the rage noise but the noise and heat are the drawbacks and the performance and tone are the positives. The pipe does make good power Like Drew said. There are really no heat shields for it so the only option is to wrap the pipe, and that, for sure will lead to premature failure with the temps that thing puts out. If you order the heat shields, you will see there isn't there to keep the heat away from your legs.
I missed the article in AIM. Must check again.
Appreciate the heads up on the heat shields. For some reason I thought they were doubled wall, i.e., built in heat shield.
I like the long tube header bent around the front of the motor and the short termination of the muffler. I've never heard a set of Road Rage pipes. I have heard the twin single pipes and they are LOUD.
Only other complaint was weld quality of the brackets and the 2-to-1 reducer.
Bassani
I haven't had any quality problems except the ceramic finish is porous and soaks up what ever touches it. Someone spilled a soft drink on it at at a local dealer when it was dyno tuned. I didn't notice it till a couple of days later after it was cooked on. Thank God for black high temp bbq paint.
Heads up on the loudness this thing produces. I DON'T think it would be legal in NC. I moved back to TN six years ago from NC and they are **** about some laws. There are baffles in the pipes but they do NOT lessen the sound. Mine is very close to a straight pipe as far as loudness. I have ridden behind guys with straights and I know.
Good luck and keep us posted.
http://www.americanmotorcyclist.com/...isltn/laws.asp
