my first oil leak...hoorah! 2007 street bob
Old 06-05-2011, 09:57 PM
freebyrd's Avatar
freebyrd
freebyrd is offline
Originally Posted by DCLXVI
This is real easy, don't fret it. You can have all this done in less than 2 hours if you take your time.
i hyperventilated a bit when i saw that picture, but scrolling through it doesn't look that bad, besides those pics were for installing forward controls and there are a lot more steps for that,
though if i had the money right now since i have to pull the casing off anyway i would probably just get the forward control kit and put it on
oh well i'll see what it looks like tomorrow in the light of day
Old 06-05-2011, 10:23 PM
midnitewolf's Avatar
midnitewolf
midnitewolf is offline
While your in there it would be a good time to do
the inner primary bearing and new style stator if
it doesn't have it
Old 06-05-2011, 10:31 PM
DCLXVI's Avatar
DCLXVI
DCLXVI is offline
He has an '07 so it should all be new style.
Old 06-05-2011, 11:59 PM
Trippster's Avatar
Trippster
Trippster is offline
It's not that bad of a job, I did it over the winter also. Same drip and all. Use your manual and do some research here on the forums (tons of info). While you have it all off change your shifter shaft seal too, its cheap and easy.
Heres a link that helped me out alot https://www.hdforums.com/forum/tri-g...ge-begins.html
Good luck.
Old 06-06-2011, 12:10 AM
Trippster's Avatar
Trippster
Good luck.
Oh, I forgot to mention, I had my rear wheel off when I did mine, so when I took it all apart I removed the belt and hung it on the wall. Then I got it all back together except for one thing. The belt was still hanging on the wall. I was so pissed. So I took it all apart again and put it back together in about 30 minutes. Second time around was pretty easy by then.
Old 06-06-2011, 12:36 AM
freebyrd's Avatar
freebyrd
freebyrd is offline
thanks, do you have to remove the rear wheel? cause one thing i don't have is a motorcycle jack
Old 06-06-2011, 07:09 AM
Trippster's Avatar
Trippster
No you don't. I already had it off for other reasons.
Old 06-06-2011, 08:54 AM
freebyrd's Avatar
freebyrd
freebyrd is offline
cool! i'll have to call the parts dept. and find out how much the seals and gasket kits are, as i said i am unemployed so i might have to rob my sons piggy bank or ride it for a while with a little drip,
thats one GOOD thing about having the black engine casing if you have a little drip, it doesn't ugly up your ride
Old 06-06-2011, 09:01 AM
freebyrd's Avatar
freebyrd
freebyrd is offline
it doesn't have it
yeah it should have the new one, it is an 07 and it was only the 06 that had that issue correct?
how would i know for sure though?
Old 06-06-2011, 12:06 PM
freebyrd's Avatar
freebyrd
freebyrd is offline
crud! the harley shops are both closed today.
i can't get the inner primary gasket
think it would be ok to ride it? its just a couple of drops and actually it hasn't leaked since the grocery store, what do you think?
sucks there should be a dipstick filler tube, guess that impractical though
Quick Reply: my first oil leak...hoorah! 2007 street bob
