Busted handle bar riser!
I, too had cheap risers, I think the bolt holes are machined off centerline a bit, so no amount of twisting and torquing will make them right. I even tried switching them side to side to see it they would even out, but that didn't help, either.
The twist didn't really bother me when riding, but that didn't matter, I wanted them straight. I finally bought T-bars to match their ergos and they aren't cast, so I now have straight bars and a cleaner look.
I just never imagined that risers could be that brittle and snap. I didn't know that they were castings either, probably made in China.
So got my new risers on. Same style and hight 4". The new ones feel even cheaper lol great. And not China made in Tiawan is that any better lol! Yeah they are rubber mounted. I think next set I will pull the rubber bushings out. I think I got them straight but tomorrows ride to work will test that.
No, I doubt if stiffer bushings will help with the alignment, I think that it's a problem with the riser bolt holes being misaligned to begin with. Both of my cheap risers had the same issue, it just gets more pronounced the taller they are.
Really? Ah crap! They are cheap *** ones. 4" tall. The goofy thing is I can push the bars straight easy but once I drive they mush back to the right just a tad to drive a guy crazy lol! I might give those bushings a shot still. Could I just run no bushing but use the same bolts and washer? Might try this too.
Have you thought about going to taller bars and switching back to stock 1" risers? (if you switch to 1" risers, you'll all but eliminate the misalignment problems you're encountering)
Your's isnt the first I've seen, and probably wont be the last. There was one recently in the softail section than broke the 1/2" bolt while he was riding. Luckily, nobody I know has gone down over this, and I hope like hell nobody does.
If you want to run solid mount without the bushing, you'll have to add a steel bushing around the bolt where it goes through the top tree. If you dont, you will end up with a wiggle wagon thats damn near impossible to ride.
SingSing
08-28-2012 10:01 PM
