Primary
Just bought the bike in October, sat in a barn for almost two years, had 4000 miles on it when I bought it. Yea, I can faintly hear a difference when I let the clutch out. Rode about 200 miles today in 90 degree weather so was hoping I was just being paranoid.
IPB is the inner primary bearing.
i believe i read another post on this subject recently, whereby it talked of calling HD customer service and getting some sort of reference number from them, for use with getting the dealer to fix it at a reduced cost.
does anyone know if this practice is still in effect and if so, did i understand the procedure correctly?
i'm still waiting for this to happen with my '06...
If you can do any wrenching yourself just get the replacement bearing from Baker. It should take less than 2 hours to change it if you go slow and the bearing is less than $50. Once you go with the Baker bearing you won't have an issue any more. When the factory bearing fails it's usually slow and obvious. It ain't leave you stranded so you could just keep riding till it gets real bad.
