06dyna extended tubes install
Service manual is a good idea.
It a fairly easy procedure, the only problem I encountered was the 12mm Hex key that was needed to pull the bolt out of the bottom of the forks, you will need an impact driver to remove it.
For removal of the seat pipe screw 12mm hex key must actually be a long one.
The 2" PVC pipe is likely the best solution for not having a proper seal driving tool.
https://www.hdforums.com/forum/frame...al-change.html
There are also some pretty good YouTube videos that cover the procedure.
http://www.youtube.com/watch?v=5ORUZ...eature=related
Muddyape
12-11-2007 10:24 AM
