V&H Big Shots, loud pops on decel
I used to have V&H straightshots and all was fine, i install V&H big shots staggered, and now when i decel from a little acceleration i get lots of pops and some are pretty loud, How can i eliminate this, is my carb to lean or rich, not sure what direction to take to cure
I do have a screaming eagle air cleaner.and a Dynojet kit installed and bike run perfect until i changed out the pipes, both pipes had the same stock V&H baffles
Any help would be appreciated
3.5 is on the upper end of whats useable for the idle jet. You can try another turn to get to 4.5 but you are pretty much open as it is. The next step is to go up on the pilot jet one size or two. One size and try 3 turns or two sizes and try 2 turns out from seated. From what you say and where you live I would go up two sizes and start at two turns. Cheap fix if you know how to change the jets which is easy. Now if you have decel pop and you have the throttle open from 1% to 33% you should shim the needle. Which is putting a shim under the needle which raises it out of the main jet giving it more fuel from......you guessed it 1% to 33% opening. After 33% or so its all main jet and the venturi takes over. I have heard of people complaining about the dyno jet needle but I live at 5500 ft elevation. If you've never changed jets, dive in. It is fun learning how it all works.
I read your post again. "explosion" makes me think air leak at the head pipe. Did you take out to old exhaust gaskets? You didnt leave them in there and doule stack them did you? Loosten your whole exhaust system and wiggle it into the head more. maybe you tightened the muffler first then the head pipe causing a gap? Quick "pops" lead me to believe a lean condition. Big "bangs" far apart sound like an air leak. Does the bie have a bad on/off throttle jerk? Like in the middle of a turn can you get back to the gas smoothly? Yes? the jetting is good. No, it jerks, the air idle is lean.
