Gas experiment
Gas experiment
Just for ***** and giggles Ive been trying different grades of gas in my WG normally I run premium.So then I run a tank of mid grade and actually to my surprise the bike ran damn good.Then a tank of regular not to good lack in response and just didn't feel right.Going to try another tank of mid grade and see what happens.
If you check your manual it may recommend midgrade. Mine does and bike runs fine on it. As long as it does not ping the lowest grade is best. There is no difference in the amount of btu in the three grades of gas. Midgrade and premium just have an additive to make the burn slower under more pressure from a higher compression engine. Years ago they use to advertise premium as having more cleaning ability. The big boys accused the oil companies of false advertising and they cut the crap out.
i prefer 91-93 but very often, even today I ran 87 octane out of a mfa tank none the less. the problem is I ride some very rural areas and sometimes am just lucky to find a station. I used to carry some octane boost but I started riding with some cats that flat throwdown the miles on bigbore baggers. They buy the highest octane available but again good portion of the time its 87. fact is I have NEVER noticed a differnce in any of the differnt fuel. If your bike is tuned good run whatever you want.
