Rpm
Received 5,211 Likes
*Are you riding solo or 2-up?
*Incline?
*Headwind?
*Even the particular gas you just put in your tank. Yesterday I was out for a whole day ride with my wife on the back....we were out in the country...came up on a no-name gas station when I needed it..had horrible gas, my engine was lugging and running like **** and I found for going up hills I was having to keep the revs up a lot more than usual.
With time, you'll learn where your engine is happy.
Yup! There's no magic number to look for if you have a tach, use your body to "feel" the bike, and use your ears. Because it's a different answer based on a lot of variables.
*Incline?
*Headwind?
*Incline?
*Headwind?
Aptly put!
As others stated, it depends on the gear.
It is much easier for the motor to gain speed in a lower gear. The gear ratio does the hard work.
Let's say in 1st you have a ratio of 5:1 much easier to twist the wick and go from 1500 RPM to 3000
Try that in 3rd or higher and it is very hard on the motor where you have let's say a 2:1 ratio. The motor cannot rev up as easily and you overwork the engine, and can possibly cause damage.
You will also find she runs much smoother in the 2500-3000 range than she does below 2200, at least for most stock motors.
It is also much less efficient at those lower RPM's and will most likely get worse gas mileage as well.
