Bike Leaning - Driving Me INSANE!!!
Old 05-26-2011, 09:15 PM
vtwinhd59's Avatar
vtwinhd59
vtwinhd59 is offline
Originally Posted by RAWHIDE07
My bike used to lean to the left also until I moved my junk to the right side of my pants,problem solved!
Its hard being guys like us...Name:  85599572.jpg
Old 05-26-2011, 09:24 PM
drnk_n_publick's Avatar
drnk_n_publick
drnk_n_publick is offline
I used to have the same problem with my '09 Bob. Not only did it lean, but when I took my hands off the bars the bike would actually veer to the left. Being my first Harley, I assumed this may be normal because of the huge primary hanging off the side. I took the forks apart to powder the lowers last winter and found that the left fork oil level (the side I was leaning too) was considerably lower than the right. Rebuilt the forks and made sure both had the same amount of oil and now the bike rides straight and true.
I'm assuming the bike came from the factory with the low fork oil condition because it rode like that from day one. I would be willing to bet your problem is either in your forks or rear wheel alignment.
Old 05-26-2011, 10:27 PM
p51bombay's Avatar
p51bombay
p51bombay is offline
democrat?
Old 05-26-2011, 10:51 PM
DSnoopy's Avatar
DSnoopy
DSnoopy is offline
Originally Posted by confederate
I'll be glad to help ya snoop, but this is gonna hurt. Your leftist political ideology has gone and infected your fine scoot. Rest easy my friend, this will all go away once you fully grasp the understanding of what common sense truly means.
LMFAO!!!!!
Always good to see you too Confederate!
Old 05-26-2011, 10:55 PM
DSnoopy's Avatar
DSnoopy
DSnoopy is offline
Originally Posted by p51bombay
democrat?
Lol. No. But anyone left of Sarah Palin's shotgun is a wacky liberal to some people around here!
Old 05-27-2011, 02:31 PM
tpapa's Avatar
tpapa
tpapa is offline
Are the rear shock spring preload settings matched - same setting for both sides?
Old 05-27-2011, 02:43 PM
DSnoopy's Avatar
DSnoopy
DSnoopy is offline
I turned the rear shocks all the way down, and also measured the front forks. Front forks are even. But bike is running a little straighter now. I plan to look into the wheel alighnment next tire change.
Old 05-27-2011, 03:02 PM
SuperFastGlide's Avatar
SuperFastGlide
SuperFastGlide is offline
you should check it now.. all you need is a ruler... if its out of alignment your wearing out your rear tire prematurely
Old 05-27-2011, 03:08 PM
Ouscazz's Avatar
Ouscazz
Ouscazz is offline
And possibly belt, and sprocket..
Go check the rear wheel alignment right away.
Old 05-27-2011, 03:32 PM
cjlandry's Avatar
cjlandry
cjlandry is offline
I just found a pdf file explaining how to do it with fishing line and a rubber-band. Seems pretty simple and easy to do. I'll be doing it as soon as I get home from the sandbox.
http://www.motorcyclemetal.com/downl...e%20Simple.pdf
Quick Reply: Bike Leaning - Driving Me INSANE!!!
