Need some help
I hope I did not misunderstand the question -
Here are some links for replacing (clutch) levers.
I hope this helps.
http://www.hdtalking.com/other_servi...tch_lever.html
https://www.hdforums.com/forum/other...ch-levers.html
http://www.***********.com/how-s/326...ake-lever.html
http://www.ehow.com/how_5820097_chan...er-harley.html
http://www.ehow.com/how_7167606_harl...tructions.html
I hope this helps.
It is very easy. Collapse the clutch cable adjuster in front of the engine until the handle touches the grip. Then take off the small snap ring on the bottom of the handle pivot. Pull the handle out of the frame and push the plastic cable holder out of the handle. Put the new one on, and back track through the steps to finish the job. You have a bit of play in the handle with the cable adjusted correctly. You manual should tell you how much.
