View Poll Results: In-Town "Cruising" RPMs - Rumble or Whine?
Keep the RPM as low as possible - better mileage and cool rumble
63.64%
Rap it out - the motor LIKES to scream, and the oil flows better at high RPMs
18.18%
Choose a different road; one that allows you to shift frequently
0%
Why are you pying attention to speed limits on a straight level road?
18.18%
Multiple Choice Poll. Voters: 11. You may not vote on this poll
In-town RPMs?
Old 05-24-2011 | 09:15 AM
JHL-ShinySideUp's Avatar
JHL-ShinySideUp
Default In-town RPMs?
Lower revs for mileage, or higher RPMs for engine friendliness?
There are a couple of roads I use pretty frequently where I'll go up to two miles without a stop sign or signal light, where the speed limit is either 35 or 45.
At 35, I can be in one gear at 2200 RPMs, or drop down a gear and cruise at 2800. Basically the same thing at 45mph, only it's closer to 2500vs 3200.
Which is better for the bike? I don't want to lug the engine, but these roads are (mostly) flat, and riding at a steady speed at 3000+ RPMs the bike just doesn't sound as happy.
It's a 99 Dyna, TC88 stock motor if that matters.
Last edited by JHL-ShinySideUp; 05-24-2011 at 01:17 PM. Reason: 300 RPMs would REALLY be lugging it!
Old 05-24-2011 | 11:46 AM
yso191's Avatar
yso191
I didn't vote because none of the answers work for me. The bottom line is running your bike at 2200 is not going to lug it unless you crack the throttle or somehow put strain on the motor at that RPM range. Just putting down a flat or downhill road - no problem. I usually do this for sound issues: going through a quiet neighborhood, or just to make it sound a bit more like an old classic Harley.
Another point: Actually your best fuel mileage comes at the peak of your Torque curve. That is where your motor is most efficient. On my bike that goes from 3200-4200 RPM. I think Stock it was a bit lower, like 2800-3800, something like that.
Steve
Old 05-24-2011 | 12:03 PM
vizcarmb's Avatar
vizcarmb
I cannot deal with the vibrations I am getting through the pegs, so I keep it at a higher rpm to be more comfortable. 6th gear is rarely, if at all used. Around town the highest gear I'm in is 4th and I'm going about 50-60mph comfortably.
Old 05-24-2011 | 12:04 PM
paulies 07's Avatar
paulies 07
I agree with Steve
Northbound Southerner
07-01-2012 01:45 PM
T_Sebastian
01-08-2012 08:08 AM
halfbreed
38
07-14-2011 03:25 PM
bstreet
01-10-2010 02:14 PM
dlrshort
05-23-2009 09:58 PM
