2011 dyna fat bob rear brake
Old 05-21-2011, 04:11 PM
FLdynapilot's Avatar
FLdynapilot
FLdynapilot is offline
Default 2011 dyna fat bob rear brake
My Fatbob rear brakes don't seem to slow the bike down real well... Tried bleeding them... No difference. I don't think I could lock the back wheel if I tried... Do I need to dig deeper or is this a Harley design to keep the rear wheel from locking up.
I use the front brakes mostly but i'm concerned the back brake is very weak... Any input?
Old 05-21-2011, 04:37 PM
King_O_Road's Avatar
King_O_Road
King_O_Road is offline
check the banjo bolt for the rear brake cylinder... Mine was seeping and the brakes got really soft to none at all. Replaced and refilled... no problems since... Good luck.
Old 05-21-2011, 04:44 PM
TORQUEY's Avatar
TORQUEY
TORQUEY is offline
Do you have anti-lock brakes? I think if you have the security option, you also have the AL brakes. Nope...just checked. No antilock option on Dynas. That's weird, too, since the option is available for Softails.
Old 05-21-2011, 05:21 PM
O-Town D's Avatar
O-Town D
O-Town D is offline
"My Fatbob rear brakes don't seem to slow the bike down real well... "
My '010 is the same way - have to press down fairly hard on the pedal just to keep the bike from rolling on a slight slope. Not likely the rear wheel's gonna lock up in a panic stop, even without ABS. And the odd thing is my rear pads are wearing out faster than the fronts, so I'm adjusting my braking method to compensate - a little more front and a little less rear.
Old 05-21-2011, 08:25 PM
SteveO-ll's Avatar
SteveO-ll
SteveO-ll is offline
? Have you adjusted the brake rod at the rear master cylinder yet to give you a little better peddle angle at the peg?
Old 05-21-2011, 08:29 PM
p51bombay's Avatar
p51bombay
p51bombay is offline
Its a new bike - its under warranty - tell the dealer to fix the thing while you eat their donuts.
Old 05-21-2011, 08:37 PM
Dynaglide68's Avatar
Dynaglide68
Dynaglide68 is offline
Old 05-21-2011, 10:37 PM
reclaimer53's Avatar
reclaimer53
reclaimer53 is offline
My 2008 Fat Bob can lock the rear up with a good stomp on the pedal. I agree it does not hold well on a hill. I suggest a pad change.
Old 05-21-2011, 11:31 PM
Lincoln33's Avatar
Lincoln33
Lincoln33 is offline
[QUOTE=O-Town D;8351082
have to press down fairly hard on the pedal just to keep the bike from rolling on a slight slope. ~[/QUOTE]
Same for my 10 SB, must be in the design, been that way since new.
Old 05-21-2011, 11:44 PM
Just Enough's Avatar
Just Enough
Just Enough is offline
EBC double H sintered pads, $35 from Amazon, easily a 15 to 20% improvement in braking performance over stock pads.
Quick Reply: 2011 dyna fat bob rear brake
