Changing from standard to Synthetic oil
Old 10-29-2006, 03:45 PM
NEONNIGHT34609's Avatar
NEONNIGHT34609
NEONNIGHT34609 is offline
Default RE: Changing from standard to Synthetic oil
u will never get every drop out but i usually go half the miles on the first synthetic oil change and drop the oil/filter this way with the second oil change u are pretty much full synthetic and cleaned out ..
Old 10-29-2006, 04:00 PM
rkoko164's Avatar
rkoko164
rkoko164 is offline
ORIGINAL: Cage996
... changing from standard oil to synthetic. I realize its a one way switch you can go to it but not back ...
I've heard that statement before. What's the danger if you went back to non-synthetic oil?
Old 11-05-2006, 02:51 AM
WildBill76's Avatar
WildBill76
WildBill76 is offline
Just change to synthetic. You will be just fine.
Old 11-05-2006, 02:58 AM
DougsDyna's Avatar
DougsDyna
DougsDyna is offline
ORIGINAL: bronk
Made the mistake of putting 3 full qts in when I did my first oil change to Mobil 1.No big deal just had to drain a little out after I drove it around the block.
Yeah, the Harley stealer did the same thing to me a the 1k, so they don't get my bike no more for notin',
DougJ
Hdglide65
Oil Archive (no new posts)
29
08-06-2023 08:38 AM
babaharley
03-25-2018 03:53 PM
joe10softail
03-26-2016 07:50 PM
r0ck3r
05-24-2010 09:50 PM
ajonojono
08-19-2008 09:01 PM
Quick Reply: Changing from standard to Synthetic oil
