fork springs , are they worth swapping out ?
anybody swap out their fork springs for progressive or another brand ? not looking to lower it , just wondering if there is an improvement in ride. wifes FXR seems to have a softer front end and rides extremely well where mine seems pretty harsh on the highway bumps
1 Post
You may want to consider the Ricor Intiminators also, they make a huge improvement in handling.
Check:
http://store.ricorshocks.com/default.asp
Check:
Received 4,761 Likes
The way the older forks are constructed you can change the oil viscosity without taking the forks out of the trees. I changed the oil weight from 5W to 10W (Belray) and noticed some better compression rates. The progressive direct replacement springs have a different coil windings rate which control the compression. Have I tried the springs? No. I got what I was after with the oil difference.
Check:
Check:
+1 I put these in my fork tubes along with the progressive standard length springs, I really like the results but since I did both at the same time I cant say which one made the biggest difference, btw I got a 20% discount (I think) on the ricor intiminators by using a coupon code from the HDforums site. I cant remember the coupon code off the top of my head but I searched for it on here and found it before I ordered.
Motorcycle
Ridin 08 fatbob 30k, forks always seemed a little soft... This
winter put in progressive springs. Not lowered. Use screaming eagle
fork oil. You will love the feel and improvement. Money well spent.
Also added tru trac this winter,.. You will not believe the difference
in the ride of your bike, specially two up riding.
Best alarm clock is sun on chrome!!
Check:
Check:
The factory springs on the newer bikes is progressively wound although I'm not sure at what rate. You can replace the factory spacers in the front if you want to increase preload. Since the springs are progressive this will make the spring rate higher and the suspension firmer. I wouldn't go with too much higher viscosity oil. Too thick slows suspension movement and will do nothing for a weak spring rate. Personally I prefer straight rate springs with RaceTech's emulators. I have never used the Ricor ones but I've never heard anything bad about them.
I've been looking into this myself. I've found that a set of springs tailored to your weight and riding style costs the same as the progressives that are generic. Lets face it, we're not all 150 lbs. and ride casually. So a couple of places to think on...
http://www.racetech.com/page.aspx?id=59&menuid=67
http://www.traxxion.com/harleydavidsonforkrelated.aspx
They also have emulator pkgs.....maybe more than you need. I do like the fact that it's tailored to your weight though, couldn't possibly be a bad way to go. Haven't pulled the trigger yet, but I will definitely go this route.
