rear shock set up
rear shock set up
blackin out my street bob and looking at a set of black progressive 412's. Would like to lower the bike in the process.. What is the best set up of lowering blocks and shock length? dont want to be scrapping my pipes.. also are the 412's an upgrade over the stock shocks? i am 6 ft 175 lbs.
Just use shorter shocks without lowering blocks. That way your shocks work at a better angle than with lowering blocks. The 412's are better than factory but I think just about anything is. If you can swing it the 440's are really good and you can adjust preload without a tool on the 440's if your load varies.
