LED Replacements for 1157's?
I got some from Pepboys once and they didn't fit. Well, they could illuminate correctly, even get proper turn signal operation without a load equalizer, but the shape of them prevented them from being fully seated in the turn signal houseing.
Jbrown, which ones do you have and did you need a load equalizer?
I went with LED cluster inserts on the rear from custom dynamics, remove the bulb, add the clusters, very easy. They are super bright.
http://www.customdynamics.com/harley...gnal_retro.htm
I'm running these.
http://www.amazon.com/gp/product/B000TK3TPO
direct fit and no load equalizer needed.
Now, where's a good source for the smoked lenses?
As far as smoked lenses go I got these...
http://cgi.ebay.com/ebaymotors/HARLE...#ht_2936wt_941
They were a direct fit but these are pretty standard. Just do a search on ebay and you'll have plenty of results. Good luck
