99 wide glide.. no spark.. help!
Old 05-13-2011, 05:53 AM
MAGNUM717's Avatar
MAGNUM717
MAGNUM717 is offline
3rd Gear
Default 99 wide glide.. no spark.. help!
hello all, some help would be greatly appreciated,rode the bike wednesday, no problem,thursday morning, no start, checked and no spark to the plugs. i was told it was most likely the crank position sensor, i can't afford to buy parts that i don't need ( who can?) can anyone help me troubleshoot this problem and zero in on the culprit thanx in advance for your input
Old 05-13-2011, 10:57 AM
johnny5jz's Avatar
johnny5jz
johnny5jz is offline
I think the connector for the sensor is under your seat. Follow the wire from the engine to the connector. Turn over the motor slowly and you should voltage interruption at certain points during rotation. If not the sensor is bad. I think it is usually about 5 volts. The manual shows checking between the black wire and one labeled BX. I looked specifically but hopefully this helps some.
CharlieBandroid
11-21-2015 03:19 PM
MAGNUM717
05-12-2011 10:03 PM
bcw901
08-04-2010 08:36 AM
huey408
11-10-2009 04:18 PM
JDixon
06-05-2009 02:10 PM
Quick Reply: 99 wide glide.. no spark.. help!
