Super Glide shift problems
Here is an “ask the experts” question:
I have a low mileage 2009 super glide. I have had past problems getting it into first gear. This is what happened the other day.
· Rode to work, outdoor temp 61 deg.(no problems)
· Bike sat out in sun, outdoor temp 91deg.
· Went for a ride at lunch, outdoor temp 91 deg. (shifted up to fifth gear and could not get it to shift back below fifth)
· Rode home after work, outdoor temp 91 deg. (could only shift fifth to sixth and back. Would not go into lower gears)
· Made it home in fifth gear and put in garage. Clutch was disengaging.
· Went out a few hours later and it went right into first, and thru all the other gears easily with out even starting it. Outdoor temp 76 deg.
Have been running Mobil 1 full synthetic in primary and gearbox. Switching back to HD fluids this weekend. Fluid levels look to be right on.
Any thoughts or ideas?
Had a similar problem on mine,a '97 FXD,a little different,I couldnt get back into first when the bike got hot.Turns out it was the connecting rod that went thru the primary.Mid controls,of course.There is a "tube" that the rod passes thru inside the primary.It was full of gunk,when the bike got hot,the rod would expand and bind up inside the "tube" causing the shifter to not return to the "in between" position.My mechanic just had to open it up and clean the rod and the tube.Said it was caused from the bike sitting unused for the year and a half before I got it.
Does the shift lever return to the "neutral" and by neutral,I dont mean actual neutral but the lever should rest in a position where you can kind of move it up or down without actualy shifting to the next gear.It does that between all the gears.If that is the case then maybe something else inside is binding.
Received 4,596 Likes
The only work has been a chrome primary cover which would include a fluid change. This weekend I am changing trans and primary fluids using OEM HD. While I have the cover off I will check the clutch adjustment and tension on the cable. Right now the cable does have a very small gap (maybe to small) at the lever. Good weekend for it, 51 and rainy.
