Pop! Then Nothing!
Pop! Then Nothing!
Well, got the bike out getting ready to go to work. Started fine when I pulled it in front of the house. Turned it off for a few minutes to get some things. Went to start it up again. Turned the key on as normal. When I hit the start button, I heard a pop. Sounded like electrical. After that, no power at all. Had to push it back in the garage. No lights or anything will come on.
I had similar happen to my bike, a loud pop sort of like a backfire upon start up but I still had lights. I turned my bike off let is sit, turned it back on and let the oil light/pump completely go on and off and then attempted another start up. I would check you batter connection first, and then fuses. I had a bad connection and a fuse blow on me last year. Did you have your bike on a battery tender? Did you ever let your battery drain? I have found that these batteries don't like to be drained because they never recover....
Now, if I can just keep the pulley bolts tight. just replaced them a week ago and are loose again...with red loctite and all. I shredded all 5 a week ago. The bolts that were in there were not the right bolts (bought the bike used). Might have messed up the rim when it happened....the pulley still sits on there centered though.
