axle tool: 28mm socket=18" crescent wrench haha
I torque all the critical fasteners on my bike so I do not overtighten them. If you think about it the torque spec for the lug nuts on 4Runner is 84 ft lbs which is more than the bike. I have put them on with a breaker bar before and been at 75 lbs before I hit them with a TW. But I torque them because then the face of the rim is even all the way around with the face of the flange and you get better/straighter tracking due to less runout. So torquing fasteners sometimes has a lot of effects on systems than just keeping the fastener tight. The lug torque on my Yukon Denali was 140ft lbs
The axle nut is a critical fastener, one of the most critical. The periodic service recommended by Moco is to check torque on all critical fasteners. Most forum members who do some of their own maintenance probably know this. But I have seen so many threads posted here on fasteners that have been broken, rounded-over, stripped, or otherwise so fubar'd that a professional had to be hired to fix it.
Two sticks and some bailing wire, indeed. Reliable torque wrenches, suitable for an axle nut, can be purchased for as little as $15. So it seems irresponsible, to me, to hear this kind of advice from a supposed professional.
Maybe I have too much pride in my work... I am sure no one would want me to wing it when they show up in my ER
If you've done it a "thousand" times and started with a torque wrench in the beginning, you'll probably get awfully close to the right torque just from experience with a crescent wrench. The guys in the Service Dept are a good example.
If only wrenching on your own bike once in a while, a torque wrench really isn't too much extra effort.
your probably right and I wouldn't be surprised to find out that a number of our members probably spoke poorly about the state of their bikes after getting them back from these same service departments. I trust the dealerships I have been associated with and know all the service personnel, but comments like these are why I am happy that I do all my own servicing. And my life means more to me then someone's idea of a short cut.
