When to do stage 1 upgrade
Old 05-11-2011, 01:33 PM
crazyanimal's Avatar
crazyanimal
crazyanimal is offline
It is my belief that the HD download only raises the rev limiter,that's it.
Old 05-11-2011, 01:37 PM
Foxster's Avatar
Foxster
Foxster is offline
Originally Posted by tpapa
OK - Today I got confused. I went to a Harley dealer to look at the Harley performance ventilator (screaming eagle air cleaner) and their expert told me that even though I have Rush slip-on's with 2 1/4" baffles that I will not need to "download" to the ECM upon adding the SE air cleaner. He said that since my 2011 has the oxygen sensor, the stock ECM will automatically compensate for the air cleaner and Rush slip-on's via feedback from the O2 sensor. He said the only thing the download to the ECM would change would be a new rev limiter setting. Anybody know if this is fact or fiction?
Its true. Since the new Delphi EFI was introduced you can do stage-1 hardware changes and the ECU will adjust for that hardware.
Of course, it will only keep the stock AFRs, which are lean. Plus you have spent $x00 on a load of shiny parts and are making little use of them other than to make noise and look pretty.
Old 05-11-2011, 03:08 PM
js0777's Avatar
js0777
js0777 is offline
Hey man, you just bought a brand new Harley. Relax, enjoy it stock for a little bit. Take some time to figure out exactly what you want to do with it. There is plenty of time to add on goodies down the road.
Old 05-11-2011, 07:05 PM
hddan502's Avatar
hddan502
hddan502 is offline
Road my 07 box stock for first 1k or so, then added pipes. In 08 added a A/C, PCIII and a dyno tune, much better. This spring, added Woods 555 cams and a dyno tune....much, much better. Next either head work, 103 c.i. kit or bump the compression a tad. It is fun to do 1 change at a time and feel and see the results, or lack there of. just my .02
abadley
Milwaukee Eight (M8)
46
08-01-2018 03:12 PM
wskadavis
05-24-2018 07:21 AM
Gritz72
19
11-24-2016 08:35 PM
KWC6
09-21-2014 12:12 AM
twig
01-12-2014 07:07 PM
Quick Reply: When to do stage 1 upgrade
