race download on the 2006 bob ? who has it
RE: race download on the 2006 bob ? who has it
ORIGINAL: Shovelhead Bob
You have the WRONG Download........
You have the SE II's, and I showed you that the flash you have is for SEAC and STOCK MUFFLERS........
You need to have the RACE Flash, PN 34399-06, the 8 degree version.....
Street Legal/Race: Race Only
Digital Tech Part Nbr: 34399-06/DT
1X Cartridge Part Nbr: 34400-06
Calibration ID: 34399-06
Description: 1450 STAGE 1 RACE
Restricted Power: Unrestricted - (Full Power)
Req'd Configuration:
Region: United States of America (Remaining 49 States)
Model Year: 2006
Platform: Dyna
Model: FXDI, FXDCI, FXDLI, FXDWGI, FXDBI, FXDI35
Exhaust System: Screaming Eagle Pro (Race Only)
ECM/ICM: 32498-05,32498-05A,32534-05,32534-05A,32534-05B,32852-06,32852-07
Cylinder Heads: Original Equipment
Engine Displacement (cc): 1450
Fuel Injectors: 06 Twin Cam 8 deg Injector (27625-06)
Air Cleaner: SE High Flow
Throttle Body/Induction
Module: Original Equipment
Cam Shaft: Original Equipment
Pistons: Original Equipment
O2 Sensor: 27683-06
ORIGINAL: hd_sob
It is bone stock except for the hi-flow a/c kit and SEII slip-ons...
Model Year: 2006
Platform: Dyna
O2 Sensor: 27683-06
Just to confirm: I have the 25 degree injectors installed. Should I STILL get the 8 degree version you recommended above? I called the local Stealer and had them look up the part number of the download they installed at time of purchase ( 34238-06) and was told the nomenclature on that particular cartridge is '06 Dyna Stage One', which is what I have. Now I'm even more confused.
Please clarify exactly WHAT download I need to make this thing run better...
THANK YOU!!!
34238-06 This is the cal ID that you said that you CURRENTLY have installed in your bike..... This cal is for 8 degree injectors..... THIS IS WHAT YOU STATED......
So I posted the cal for the 8 degree RACE, Which is what you SHOULD HAVE INSTALLED........
The cal that you have is for 8 degree injectors, SEAC only, no exhaust modifications PERIOD!!!!!!!!!!!
If you have the 25 degree injectors, then you should have this one.... 34385-06 CAL ID.....
Digital Tech Part Nbr: 34385-06/DT
1X Cartridge Part Nbr: 34386-06
Calibration ID: 34385-06
Model Year: 2006
Platform: Dyna
Fuel Injectors: 06-07 Twin Cam 25 deg Injector (27709-06 / 06A)
O2 Sensor: 27683-06
For the 06 model year there were 2 different Stage configurations, LEGAL and RACE....
Legal retains the factory mufflers, Race utilizes the SE Mufflers.....
Model Year: 2006
Platform: Dyna
O2 Sensor: 27683-06
NEONNIGHT34609
17
01-23-2007 11:28 PM
chapds
11-06-2006 01:53 AM
