06 Superglide speedo not working
I am hoping someone can help, the speedo on my 06 Superglide just stopped working. I have checked the fuse and it's good. I was thinking maybe an electrical problem as I have seen previous post similar to this but didn't see any resolutions. Everything else electrical is fine, lights, turn signals, horn etc.
Any help would be appreciated.
Take the 2 small allen screws out of the back of the speedo and twist off the trip meter button,the back plate will come off, check to make sure the plug in the back of the speedo is fully seated, some die-electric grease on that connector might be necessary if it has some corrosion on it. Hope this helps.
