Have you guys ever had to replace the battery in your key fob?
So I was dumb and waited a little long between starts this winter and ran my battery down low.
I put it on the charger and back on the bike - the accessory lights are all bright and it looks normal, but nothing happens when I press the start button? when i switch the lever to "run" it makes the same noise and has the little orange light that you wait for before starting but nothing happens when I get to pressing start?
any ideas?
Could my battery in my key fob be done and maybe not registering?
any ideas?
Received 4,808 Likes
I started noticing the alarm beeping while I was riding. A few days later when I wanted to push the bike out of my garage, the alarm went off... Figured the FOB battery was out. I just changed the battery and all was well.
As far as the FOB not working... when you dont have your FOB close the turn signals blink before the alarm goes off. I'm guessing you can still move your bike around without the alarm going off, so it's not the FOB.
Same here replaced both batteries after 3yrs. I did have a problem with my alarm last year though. Bike turned on, all lights and fuel pump primed but wouldn't start and the lights started to flash. At first I thought it was the fob but after having the gf bring me my spare it still wouldn't start. After messing with it by turning it on and off again and again it finally started. I stopped by my local dealer after getting it started and they checked it out and found the alarm system itself was going bad. They covered it under the warranty luckily cause it's like $330!
harley_jeff
04-22-2009 03:43 AM
