Engine Noise Driving Me Crazy!!!
Old 05-02-2011 | 06:12 PM
Captain Itch's Avatar
Captain Itch
Sponsor
Originally Posted by JRK5892
20 0z of the lucas for me as well... i have heard the tick in mine goes away with the lucas... i thought i had a pushrod that came out of adjustment
I use this in everything..
__________________
www.Captain-Itch.com
Old 05-02-2011 | 06:32 PM
SBRob's Avatar
SBRob
Originally Posted by 8541hog
45-50 in 5th going uphill will certainly cause some clattering.. Drop at least 1 gear. You are probably only doing about 2000 RPM at that speed.
Ditto...at 50 mph in 4th gear my bike's only turnin' 2500 rpms. I never use 5th gear until 60 mph and the motor's only turning 2600 rpms.
I try to stay between 2600-2800 rpms when criusin'.
Old 05-02-2011 | 06:46 PM
OldMike's Avatar
OldMike
Originally Posted by lhgdale
I would say 45-50 mph. I did just change from a helmet that covered my ears to a Voss half shell. I'm shure that's part of it but man it's alot of noise.
I have been wanting to invest in a tachometer that way I can judge the rpm's better. To me the thunderheader makes it sound like you are at a higher RPM than you really are, just my opinion though.
Thanks for the comments. I appreciate it.
What you are doing by rolling power on at too low of an RPM is like taking a hammer to the inside of your engine and beating the rod bearings to an early death. You don't need an oil additive you need to learn how to ride.
Old 05-02-2011 | 07:02 PM
lhgdale's Avatar
lhgdale
When just cruising is there a certain speed that is best to shift at?
I have been shifting into 2nd = 20mph, 3rd at 30mph, 4th at 40mph, 5th at 50mph and 6th at 60mph. Like I said before my pipe really makes the rpm's sound high.
Old 05-02-2011 | 07:13 PM
OldMike's Avatar
OldMike
I'd say you're shifting too soon even for just cruising.
If you grab a handful of throttle and you hear pinging you need to downshift. It's just like an automatic transmission in a car going into passing gear, gotta keep the RPM's up when passing.
Learn to ride with a bit more RPM so you're not lugging the engine.
Old 05-02-2011 | 07:20 PM
Jackie Paper's Avatar
Jackie Paper
You are talking two different things but I will address pinging which I think you are talking about. Synthetic oil is not going to measureable affect this. You need a better grade of gas and lower gear for more RPM. You are putting too much load on it not matter what you think the RPM is. You can be going 65 in 5th at 3000 rpm and WOT on a hill and cause it to ping. A higher octane gas will burn slower and not explode like a lower grade which causes the ping which is the piston ,valves and crank bearings shaking but even that will not help if you have too much load on it.
Old 05-02-2011 | 07:30 PM
lhgdale's Avatar
lhgdale
Thanks for all the info. I think I need to invest in a tach, since it's obvious I can't really judge engine rpm by ear.
On the Lucas oil stabilizer, how do you come up with 20oz?
Old 05-02-2011 | 08:37 PM
bobgv's Avatar
bobgv
Great post was experiencing that annoying pinging\ticking noise as well and it seems louder since I installed the Rineharts. How do you add that Lucas oil, do you replace the 20 oz. of 20w50 or do you add it after and is Amsoil better than the HD synthetic oil. Thanks
Old 05-02-2011 | 09:37 PM
lo-rider's Avatar
lo-rider
I have just about had it with the ticking/pinging coming from my engine. I notice it most when the engine is under load...For example there is a hill on the way to my house that I take in 5th gear. I roll on the throttle and the ticking is very loud....
I appreciate any help..... Thanks
You are ruining your motor.
Old 05-03-2011 | 12:09 AM
lhgdale's Avatar
lhgdale
If anything I am trying to baby my motor and take it easy. I don't dog out anything I own. I do understand (now) that the ticking/pinging is caused by lugging. I will just keep the motor in the higher RPM's from now on, even if it seems to high.
Quick Reply: Engine Noise Driving Me Crazy!!!
