FXDX handling monster
Was checking out this guys build, http://www.dub-performance.com/en/index2.html
Really diggin the idea of something like it.
As for the brakes, to be honest I have no idea. He's worked as a mechanic for almost as long as I've known him and he laced that front wheel himself so I know he could have ran a dual disc if he wanted to. I think it was a setup he was comfortable with at the time.
Sharkey, thanks for the reply and the insight. You got some pics of your feather weight? Or a build thread?
The build thread would be back a few years; basically a Headquarters 103 with 111hp/117ft lbs; best part of the engine build is 100ft lbs at 2200RPM; there's some pics in my profile...
Should be just under 600lbs come spring; still heavier than an FXR and without the FXR swingarm.
Imagine a 113 inch twin-cam FXR with all the diet stuff...expensive but WOW...
Everybody should live at least one dream.....
Chopper guys frame, stock twin cam 88 with 1000 miles.... 6 speed TP trans one of a kind billet wheels matching rotors and pulley.... Super trapp exh, Fxdx front end works shocks.... Holeshot T-Bars.... Autometer gauges, HD primaries and clutch, will change anything cosmetic including any color paint and will put 95" kit in with 211 cams and adj push rods!! Everything powder coated black!!
You mean I have to get off of it?
My stock FXDC handles pretty good, it's just ground clearance issues that bug me.
I'll be watching this thread closely, may be just a drop more height (and better dampers and spings) will help without screwing up the looks.
You mean like this.......He wants $16k for it.
