The Easy Way To Remove LocTited Bolts
Old 04-28-2011 | 12:53 AM
lo-rider's Avatar
lo-rider
Default use the right tools
The attached photo shows my basic stubborn fastener removal kit. The impact driver w/ the correct quality bit (used after some Aerokroil penetrant has been allowed to soak in) will save a bunch of cocking around w/ drills and EZ-Outs, after the head has been mangled by improper technique. The force of the hammer blow drives the bit into the bottom of the fastener's recess, assuring full contact and avoiding cam-out, protecting the fastener.
Note: The torch and big hammer are for intimidation purposes and for particularly troublesome jobs.
Attached Thumbnails The Easy Way To Remove LocTited Bolts-fastener-removal-crn.jpg
Old 04-28-2011 | 01:10 AM
abadv8's Avatar
abadv8
I actually have a 1/2" impact gun that I use just for stuck, stripped, rusted, or otherwise defunct fasteners. #3 Phillips are particularly troublesome for some metric bike owners as a) they don't know that there is a difference between a #2 and #3 head and b) some of them don't belong in a garage holding tools in the first place.
Anyways, someone makes a 1/4" bit holder for a 1/2" impact gun... works awesome... even on some of the heads that I think "there is no way this is coming out".
I thought I'd chime in with "don't fear the impact".
Old 04-28-2011 | 01:22 AM
dfndr's Avatar
dfndr
Someone once told me to use an electric soldering gun to heat and loosen loctited fasteners. Never tried it but what do you think?
Old 04-28-2011 | 04:31 AM
HemiOrange's Avatar
HemiOrange
I read a tip a while back about two guys contemplating how to remove a red Loctited bolt. Before they could do any harm the one guy's wife comes out to the garage and suggests they apply some Loctite. They did and the bolt came out as if it were finger tight.
I guess the fresh Loctite dissolved the old Loctite's hold.
It wasn't mentioned what particular type of Loctite they used, but I would try the green penetrating type, designed to be applied to an already torqued bolt. I have a tube of 290 green that would work and it does a good job of locking my obnoxiously rotating forward control floorboards.
Old 04-28-2011 | 04:59 AM
Badmonkey's Avatar
Badmonkey
Originally Posted by JRK5892
also... you can put a punch in the center of the bolt, give it a good smack works great as well
new bike? new paint?..looks great love that blue.
And yea proper torx bolt with a hammer behind it works for me
scooper321
Wheels/Tires
24
02-11-2018 10:31 AM
Sharpie
General Topics/Tech Tips
16
04-18-2016 01:35 PM
Knights2TheEnd
12-21-2012 01:52 AM
rojuwi
10-26-2012 11:53 AM
Shift_4lo
01-12-2006 01:18 AM
