preload change?
I have a 2011 Dyna Super Gluide and I am a little confused here and I think it's because of the diagram and wording in the manual. The diagram shows a cam step chart starting at 3 then 4 then 5 then jumps to 1 then 2. I would think you could just turn the preload cam counter clockwise all the way but by the chart you would be going to position 2 if you did that. You guys with a user manual will know what I mean. The manual states turn the preload cam counter- clockwise until it stops. Counting one at the stop position , turn the spanner clockwise and count each position to specification (refer to table) So I just turned it 2 clicks to get to the 5 position which is 225-255lbs which is good for me and a passenger. What I am asking is when I go all the way counter-clockwise am I at the one or three position?
Looking at the diagram in the manual, I believe that the figure with the steps and the preload numbers under them is supposed to be taken as it would wrap around the shock. So 1 would be the position furthest counter clockwise and 5 would be the furthest position clockwise. It would be like cutting out that linear picture and wrapping it around the shock so that the 2 position touches the 3 position. But I could be totally wrong too.
