Rear axle nut socket size?
04-25-2011, 11:44 AM
Hi, What is the socket size for the rear axle bolt on an 07 wide glide?
Regards
Terry
04-25-2011, 12:05 PM
04-25-2011, 01:00 PM
I know it's metric.....39MM? The second parts a guess.
04-25-2011, 03:07 PM
04-25-2011, 05:13 PM
1 7/16 socket will work. Thats what I use and never rounder any corners.
04-25-2011, 09:57 PM
Hi Thanks, i tried 1` 1/8 (12 point i think) it was close but no cigar!
04-25-2011, 11:57 PM
28mm will work on the axle but for the nut you need a 36mm.....................Sears has them for about $9
04-26-2011, 01:42 PM
I got mine at Tractor Supply...But I don't know if "uze guzsz" have them in Brooklyn.
04-26-2011, 02:37 PM
Quote:
Originally Posted by
The Dean
1 7/16 = 1,4375 inch = 36,5125 mm
Put a rag over the nut with the 1 7/16 socket and you're OK...
NWI
2014-2023 Touring Models
09-15-2017 07:14 PM
aqua754
08-24-2016 03:33 PM
YellowHawk
09-23-2008 08:42 AM
artc
09-12-2008 04:04 PM
Dan B
02-05-2006 12:41 PM
2003 ,
axel ,
axle ,
davidson ,
glide ,
harley ,
hub ,
nut ,
rear ,
size ,
socket ,
sportster ,
standard ,
street ,
wheel
