Hillside 107" in the works
So I dropped the scoot off to Scott and Craig at Hillside Cycle for a few upgrades. 107" BB, Wiseco pistons, Hillside stage 4 heads, HP inc 55/58mm throttlebody, bigger injectors, swapping out my Woods 7h for their 8-6 cams, VPC clutch. I will be without a ride for a couple weeks, but the weather here still sucks so I dont mind. Cant wait to ride it though, should be a monster.
I just did that same build did it myself but used there Stage 4 heads, 107 kit, HPI 55mm TB, 5.3 gram injectors, I did the TW8 Cam, only things I added was a fueling oil pump and SE Roller Rockers which u dont need either but next time I want to go with the woods 9F cam. Anyway with my Rinehart Crossbacks which are duals like your Martin Bros pipe I made 110HP and 116TQ and that corrected the front wheel wont stay down. I was gonna do the VPC but ended up just doing a Barnett Scorpion Clutch little more money but well worth it..
I saw your Sig you where making 95HP and 112TQ with what upgrades?
Those numbers were the stock 96" with a Woods 7H cam w/ 4 degree advance gear and I had a Rinehart 2 into 1, tuned by Joe's Cycle. Since I put the Martin Bros pipes on it feels like it lost a little. The 107" should make up for it though. With the right pipe I was told that build should make around 130/130, but like you I will leave some power on the table for the sake of a nice looking (imo) pipe. (Although if its too much I will be buying a fat cat)
Here's the dyno for what I had. It did have 112 torque, but as you can see it was short lived. New build should have a nice flat torque curve. If you got your sheet post it, I am interested to see it since we will have basically the same build. Nice ride by the way.
This is just my opinion, but 130/130 out of a 107" is gonna be really hard to get unless you have a big cam and lots of compression. What have you done to the bottom end of the motor? 120/120 is a problem waiting to happen on a stock bottom end.
This is just my 2 cents.
I'm no expert by any means, thats just what I was told the build could make with the right pipe. I will probably end up in the range of Los11, which is fine by me, due to not using a 2 into 1 pipe. Scott at Hillside said they would check the crank for runout prior to the build, but if all is well welding and truing the crank isnt necessary. I believe he said the 88" was different. Check out Wood cams website for dyno charts using the 8 cam. I attached a dyno from one of their 107 builds, basically the same as mine.
