Forward control brands? good better best?
Old 10-22-2006 | 11:08 PM
flynlow's Avatar
flynlow
Default Forward control brands? good better best?
I would like to buy some forward controls for my 05 FXD but searching these forums and different net sites shows too many alternatives. Would anyone, who compared the different brands, like to post the pros and cons of the different makes? I now have mids with highway pegs that I usually shift and brake with my heels ever since I put a Corbin close gunfighter the mids are cramped even though I only have a 30" inseam. I would also like to know what extra parts I would need if I bought a model that has the master cylinder built on? Any opinions on which models would be the shortest reach, as this is a big concern?
Thanks for your time
Anthony "flynlow"
Old 10-23-2006 | 12:41 AM
Steelhorse96's Avatar
Steelhorse96
Default RE: Forward control brands? good better best?
Honstely, when i was looking around for FCs i wanted to go with a nice aftermarket chromed out look, i felt the harley kit ones looked to cheap, so i went with a set of supreme legends for my 07SB, got them off ebay for less then half full cost. Love them. I also have a 30" inseam, very comfortable to ride. I needed 2 banjo fittings, a pressure switch ,40" braided line, some DOT5 fluid.
Old 10-23-2006 | 08:14 PM
flynlow's Avatar
flynlow
Thanks Steelhorse96
I will look for them.
Anybody else?
Old 10-23-2006 | 08:21 PM
DGlide04's Avatar
DGlide04
I put the HD's on my '04 Superglide. They look good, work like they should and you only need to add a couple of footpegs and you're in business. Some forwards (Softails in particular) have the rear master cylinder mounted on right forward, I guess you could find a set for your Dyna with the m/c up front and then run a flexible brake line to the rear caliper. The stock HD forwards use a longer brake rod to the stock rear master cylinder which accomplishes the same thing.
It is a matter of what you're looking for and what you want to spend. You can go inexpensive or really expensive and detailed, it's up to you and your wallet.
Old 10-23-2006 | 08:51 PM
shooter64's Avatar
shooter64
Former Sponsor
Accutronix...hands down makes the best...
shenger
12-06-2017 08:00 PM
orange4
04-21-2012 09:56 AM
Saskrider
EVO
03-31-2012 10:39 AM
EvilWayz
Ironhead
12-06-2009 04:25 PM
Softtail Bob
03-23-2006 12:18 PM
Quick Reply: Forward control brands? good better best?
