Mounting bolts for highway pegs?
Old 04-22-2011 | 04:55 AM
YeOldeStonecat's Avatar
YeOldeStonecat
Default Mounting bolts for highway pegs?
Picked up a nice looking set of Highway Pegs from ebay.....
The type with that bracket that mounts on the sport up front on the frame with 2 bolts each, not the tube clamp type. Of course, it will arrive without mounting bolts.
I've seen a pic of the kit from HD, comes with bolts that appear to be allen head type. Does anyone know if there is a specific part number from HD? Or...better yet, what size bolts these are and I'll just pick some up a the local hardware store.
Old 04-22-2011 | 05:30 AM
Comingapart's Avatar
Comingapart
Mine's standard hex head and a lock washer.
Sorry, don't know the size off hand but I think the bolts from the passenger footpeg mount or beltguard mount are the same size and thread if you need something to take into the hardware store with you.
You'll need some spray lube too as those front mounting holes get rust and funky and you'll play hell running the bolts in the first time.
Old 04-22-2011 | 05:59 AM
Bspike1's Avatar
Bspike1
standard 3/8" X 1-1/2" bolts. Allen or Hex is up to you. Use Loc-Tite thread locker. I just put on a set. Except mine required cutting the heads off of the bottom bolt to use as a dowel. I used leftover self-tapping bolts from the passenger peg mounts for the top.
Old 04-22-2011 | 06:14 AM
Rickl's Avatar
Rickl
Harley's bracket's cost @ $125 and I was able to get Drag Specialities for @ $60. Use a tap to clean out the threads and then the bolts will easily thread in. Make sure to use "blue" loctite on the bolts. Also, I installed the Kuryakyn ISO swichblades which for the little I have used them have worked out nicely. Just make sure you loctite the screws (experience talking here, although Kury did replace the one with no problems)
Old 04-28-2011 | 05:01 PM
YeOldeStonecat
They arrived today, excellent shape, I'm happy with my find on eBay.
Will prob swing by hardware store Saturday morning to pick up the bolts.
So based on BSpike1's post..they're "standard 3/8" X 1-1/2" bolts"...anyone have an idea for the thread?
Old 04-28-2011 | 06:31 PM
Karsten's Avatar
Karsten
On my 06 SB I went with self tapping bolts as the holes are not threaded completely. Oil the bolts up well then back them out and clean everything up if you want to use Loctite.
Karsten
Old 04-28-2011 | 06:37 PM
O-Town D's Avatar
O-Town D
Originally Posted by yeoldestonecat
"so based on bspike1's post..they're "standard 3/8" x 1-1/2" bolts"...anyone have an idea for the thread?"
3/8-16 (unc)
Old 04-28-2011 | 09:30 PM
clicker01's Avatar
clicker01
Originally Posted by O-Town D
3/8-16 (unc)
LOL... yeah, standard thread.
Old 04-29-2011 | 05:56 AM
YeOldeStonecat
Thanks guys!
Old 08-06-2020 | 03:54 PM
Michael Douglas's Avatar
Michael Douglas
Default Old but anyone still watching
So I'm dealing with same situation on my 11 street bob, I'm wonder if these are coarse thread bolts or fine thread? I'm trying to tap them out .. thanks!
Update:
I tapped them with a coarse thread tap and they worked perfect.
jurakat1111@gmail.com
07-07-2016 10:53 PM
ralfie
09-29-2014 08:48 PM
Jason Oates
01-12-2014 08:37 PM
DYNARYDER87
04-29-2013 02:03 PM
lkbenson
06-01-2006 02:29 AM
Quick Reply: Mounting bolts for highway pegs?
