Installing rocks, push rods not spinning?
Old 04-21-2011 | 09:03 PM
Hickey's Avatar
Hickey
Default Installing rocks, push rods not spinning?
Hi Guys,
I finally got my rockers powdered! first off I'm pissed because I didn't even need my 7/16" dogbone adapter (only 1 bolt) cost me 30 bucks, but whatever!
Anyway, I'm installing the support plate, and as I tighten, the push rods stop being able to spin freely? before I installed the rear rocker, I found TDC (at least I thought I did, used the straw method to find the highest point).
Is this normal? should I just tighten down it down to spec? 20ft lbs and just wait for it to bleed down, will this bend the rods? or should I just do it bit by bit, which feels like it would take forever!
thanks!
Old 04-22-2011 | 02:52 AM
kk6pg's Avatar
kk6pg
As long as the ball of the pushrod is in the socket in the rocker, torque it down and run it. Unless you swapped intake and exhaust pushrods, youre good to go. If memory serves me correctly, the black pushrod is the exhaust.
BTW, if the pushrod DID spin when the rocker arms were torqued, you got major problems.
Old 04-22-2011 | 07:34 AM
Hickey's Avatar
Hickey
the manual says after pushrods are torqued, ensure they spin freely, I guess this is after the bleed down the right?
I checked this morning to put on the final torque, they spin, but not as 'freely' as they did before any torque was applied at all (just enough for the threads to catch)
Old 04-22-2011 | 11:51 PM
superrooster2003's Avatar
superrooster2003
id prolly take the rocks out lol sorry but it had to be said
Old 04-23-2011 | 04:48 AM
Spanners39's Avatar
Spanners39
No! You don't do it like that! You tighten the rocker bolts evenly until the pushrods stop spinning, go take a dump or walk the dog or whatever for 10 mins and then come back and check, when you can rotate the pushrods (they won't be slack and will take bit of finger effort) you tighten a bit more and repeat the process, usually 4 -6 stages until the rocker box or platform (depending on model) touches down, then you torque it fully...put the rocker box on and then rotate motor to next TDC and start over again.
This prevents the valves touching the pistons while the lifters bleed.
OR you take the lifters apart and drain all the oil out before reassembly and then you don't need to tighten it down in stages...bike will sound like crap when you start it but its back to normal after 5 miles
Old 04-23-2011 | 04:51 AM
Spanners39's Avatar
Spanners39
You are right about the black pushrod but wrong about the spinning, they MUST turn or the valves won't shut.
Old 04-24-2011 | 07:31 AM
sniper77's Avatar
sniper77
Pretty interesting question and replies.
One thing I would have pointed out right away was the need to know what stroke the cylinder is on instead of just making sure the piston is TDC. You see The piston is @TDC twice but the cam is on base circle on only one of those times. You could very well be tightening the rockers down with one or both valves partially open which will damage the engine.
The proper procedure is to make sure the cylinder is at the top of the compression stroke and you can determine that by feeling the lifters with your fingers or watching the lifters to note when the intake valve closes and then turn the crank a bit more until the piston is At or very near TDC , a little either side of TDC is okay since you are coming into the power stroke where both valves are closed.
Then, torque the rockers down and wait - twenty minutes - and check the see you can turn both pushrods with your thumb and finger tip. IF you CAN NOT turn both pushrods freely, with zero lash (no vertical movement whatsoever) WAIT another five minutes and try again. If after twenty-five minutes you still can not turn the pushrods - WAIT - until you can.
Then rotate the engine, I usually do three or five turns, to make sure the valves and piston never meet and set the other cylinder up to repeat the procedure.
.......But that's just how I do it.
DannyMackTattoo
03-03-2019 11:04 AM
ColoStreetGlide
Engine Mechanical Topics
25
02-15-2017 09:30 AM
Sportstatler
03-26-2014 09:46 AM
DGlide04
Exhaust System Topics
02-19-2008 06:42 PM
cleanandsimple00
08-11-2007 02:23 PM
Quick Reply: Installing rocks, push rods not spinning?
