Rear fender on 10 street bob
This is incorrect. The fatbob fender WILL fit. Just ask slipstream (i think is the name - FXD w/ AME rake kit) who put a fatbob fender on.
BUT, the wide glide bry's fender is the same except about 1/2" narrower & will be cheaper than a fat bob fender.
Anyone know if a Fat bob fender will fit a street bob? The dealer could not give me a straight answer.
The Fat Bob has been with us since 2008 & the frame still remains the same to this day. In 2008 & 2009 it was the only Dyna to sport an OEM 200mm rear tire.
In 2010 the Wide Glide was re-introduced with 200mm rear tire on a modified Fat Bob frame that has more rake in the neck. The rear portion of the 2010+ WG & 2008+ FB frames are the same and are the only Dynas that have an OEM 200mm rear tire. These frames are made for a 9" wide rear fender... that’s why the 2010+ WG rear fender is a direct bolt on swap for the Fat Bob only. All other Dyna frames ARE NOT made for a 9" rear fender.
The pre-2009 Wide Glides have a narrower rear tire & fender... that's why a PRE-2009 Wide Glide rear fender WILL FIT a Street Bob.
This is also why a Fat Bob rear fender WILL NOT FIT on a Street Bob .
Yes It will fit, its a tight fit, but can be done.
I put an 09 FB Fender on my 07 FXD Super Glide, Covers my 200 Pirelli real nice.
Here is thread with some more info.
https://www.hdforums.com/forum/dyna-...treet-bob.html
As for "will not fit", slpstrm PROVED it does.
