Torn between which air cleaner style to go with
Old 04-21-2011, 01:44 PM
Deftone5's Avatar
Deftone5
Deftone5 is offline
The heavy breather looks like a submarine coming out of the side of your bike. I just ordered a Roland Sands Design Venturi big sucker. I'll let you know how it works out.
Old 04-21-2011, 01:50 PM
Swede405's Avatar
Swede405
Swede405 is offline
The heavy breather clears leg room and I like the look of it. Never had a problem with mine.
DSnoopy's Avatar
DSnoopy
DSnoopy is offline
Originally Posted by dano8855
Heavy breather. I have heard that some have had problems with the big sucker.
What problems?
Old 04-21-2011, 01:55 PM
hd_sob's Avatar
hd_sob
hd_sob is offline
i think it looks more like a phasor or something that shoots photon torpedoes...
Old 04-21-2011, 02:42 PM
Salvi's Avatar
Salvi
Salvi is offline
I was basically torn between the round & torpedo look but heard good things about the AN big sucker and it seems like a lot of people with round ones are using either that one or the SE stage I. The RSD was also on the list but was a little out of my price range for now.
thanks for the input
Old 04-21-2011, 02:46 PM
fenderzig's Avatar
fenderzig
fenderzig is offline
I have a 2 inch tank lift and the SE heavy breather. Looks like this:
Old 04-21-2011, 03:08 PM
Salvi's Avatar
Salvi
Salvi is offline
That does look nice... I'm also doing new mirrors and chroming out the hand controls so it might all boil down to how much cash I have left over. I'm thinking the AN big sucker or SE stage I and using the round center of the stock cleaner cover as the cap. I saw someone on here did that and it looked pretty sweet. Plus that would save my cheap *** some loot.
Old 04-21-2011, 03:28 PM
hd_sob's Avatar
hd_sob
hd_sob is offline
Originally Posted by Salvi
I'm thinking ... SE stage I and using the round center of the stock cleaner cover as the cap.
that's how i had mine until i installed the heavy breather (out of boredom, mostly).
i also had a tank lift on it for awhile. i eventually removed it as it didn't seem to do much except cause me to wonder how much gas was actually in the tank...
Old 04-21-2011, 04:54 PM
kirk180's Avatar
kirk180
kirk180 is offline
ahhhhh ya know what Maclugie you might have just solved the dilemma... I'm adding a 2" tank lift this weekend so if the heavy breather blocks the cylinder that would kind of defeat the purpose of me adding the lift to show it off ya know.
I don't think the Heavy Breather takes anything away from the tank lift. I love the look of the two together. Here a couple of angles of it on my bike.
Attached Thumbnails Torn between which air cleaner style to go with-015.jpg   Torn between which air cleaner style to go with-019.jpg
Old 04-21-2011, 05:01 PM
Desertram800's Avatar
Desertram800
Desertram800 is offline
Ive got the zippers maxflow, similar to the big sucker, but a smaller diameter for more leg room. It sticks out a little farther, so that there is still the same amount od filter surface area. Plus, the smaller diameter shows off more engine, if that matters to you.
The heavy breather is on my list though, i love the look of it, aggressive and sporty.
Quick Reply: Torn between which air cleaner style to go with
