Clear shrink wrap?
Clear shrink wrap?
I have a set of Magnum cables and I was told there was supposed to be a piece of clear heat shrink that was to be placed around areas that rub against the bike. Needless to say the clutch cable got pinched a bit and there is now a small hole in the clear plastic. Does anyone know where I can find a piece of heat shrink wrap that would cover this so it doesn't cause a problem later. I was told that I could have rust issues if water leaks into the cable, didn't know that these expensive cables were so fragile.
Any help would be wonderful!
Just a couple of questions - Is the hole just in the shrink wrap, or in the cable housing itself? Moisture won't be a problem until you breach the actual housing.
And, is this pinching a one-time deal, or will this be a continual problem, even after the replacement of the wrap?
I think if it is pinching, that is something to solve before replacing the wrap. Once you do - McMaster-Carr is the place for hardware. IMO
http://www.mcmaster.com/#heat-shrink-tubing/=by7utq
