rebuilding rear caliper, help!
not as much of a rebuild as an assembly issue. took apart the rear end to get the rear wheel painted, and I saw this little brown cylinder on the ground. After looking through the manual, looks like it might be something called the 'phenolic insulator' (however I could only find one). Looks like it fits into the piston on the rear caliper.
I cant seem to find any reference to this anywhere on the site. Anyone know what these are for, if they are necessary? I put the caliper back on and the brakes seemed to work just fine up on the jack.
manual also says its only available in rebuild kit, does anyone have a part number for the rear caliper rebuild kit?
Thanks!
Thanks!
Definitely not the rubber bumper. Is it plastic/phenolic, because it looks like it is metal in the picture? What year bike do you have, my '07 manual does not mention anything about phenolic insulator? I have never seen this on either the fixed or floating caliper? Road debris?
