Throttle cruise assist?
Old 04-18-2011, 09:30 AM
Just Don's Avatar
Just Don
Just Don is offline
HemiOrange
Give the folks a call at customized cycles. They are very helpful and state on their site to call with other needs. The softail version mounts just above the frame behind the inner rear fender. I installed it myself without too much difficulty. I think their system would work if you can find a place to mount it. Keep us posted if you make the call.
Old 04-18-2011, 09:32 AM
reclaimer53's Avatar
reclaimer53
reclaimer53 is offline
Default Crampbuster
I love my cramp buster. I can't ride with out it.
Old 04-18-2011, 10:56 AM
Sharknose's Avatar
Sharknose
Sharknose is offline
www.throttlerocker.com . 10 bucks and you're good to go. I've been using them for 15 years. Just make sure you position it so that you can roll the throttle completely off without letting go of the grip.
Old 04-18-2011, 11:07 AM
skygoddess's Avatar
skygoddess
skygoddess is offline
Thanks for the replies everyone. I just bought the Kuryakyn Iso-Grips with the throttle boss so I will be able to rest my hand a bit but I still want some cruise control. Has anyone tried the Breakaway?
Old 04-18-2011, 11:36 PM
HemiOrange's Avatar
HemiOrange
HemiOrange is offline
Originally Posted by Just Don
HemiOrange
Thanks for the reply. What model did you mount it on? You say you used the softail version, but did you mount it on a softail or a Dyna?
I thought that maybe the Dynas didn't have the electronics needed for a cruise control or for sure someone would be advertising for our business.
Old 04-19-2011, 10:51 PM
Just Don's Avatar
Just Don
Just Don is offline
HemiOrange
They advertise for softail, and I installed it on one. My 05 Heritage Classic. I'm not sure on the Dyna. Although Harley doesn't offer it on the softail, my odometer was preset up for it because it has an indicator light that shines red and green depending on if it is engaged or not. I did not expect that. As I said previously, the best thing to do would be to call the manufacturer. Incidentally, all components, controls etc. were HD. I think it's the wiring and cables that they provide that are custom.
Old 04-20-2011, 12:49 AM
Andjh123's Avatar
Andjh123
Andjh123 is offline
+1 to this in terms of value and simplicity. For longer trips just position it higher up so that your hand/palm is a natural position at normal highway speeds and, unless you cruise at excessively high speeds, this will still allow you to come off the throttle without having to let go of the grip--you'll just have to roll your wrist a little further forward which you'll get used to quickly.
moose545
08-21-2018 12:37 PM
mrfikser
04-05-2011 07:34 AM
powaypete
01-23-2010 03:59 PM
MNPEEPS
04-24-2008 09:24 AM
Streetrunner
02-17-2008 03:22 AM
Quick Reply: Throttle cruise assist?
