Clutch cable replacement
I recently replaced my mini apes on my FXDWG with a set of drag bars and for the most part all cable lengths are "alright". I'm very picky and I'm considering on changing out the clutch cable because it is the worst looking. Do I have to go all the way back to the motor or can a replacement be ordered that just goes back to the adjustment mechanism?
Thanks
Thanks
It is not a difficult swap, just do not remove the arm in the trans, just unhook the cable end.
Get some fresh trans oil and drain it before you start. Pick up a new trans cover gasket as well. There is no need to adjust the actual clutch if you are only swapping the cable.
When installing the new clutch cable into the cover be careful not to damage the threads in the clutch release cover. Here's how I managed to get in the clutch cable without any problems:
1. I hung the clutch cable from the ceiling in my garage using a string
2. Sat underneath it with the clutch release cover between my knees
3. Grabbed the threaded end of the clutch cable, inserted the cable end into the threaded hole and positioned the cable in line with the cover
4. Once the two threaded parts get together, I first slowly turned the cable counter clockwise until I felt the threads falling together
5. From that point I slowly turned the cable's threaded end clockwise. When you don't feel any resistance you're OK!
