Tail light
There is a wire harness that runs under the rear fender. It is held in by clips and sometimes the wire harness pops out and rubs against the rear tire. This might be what has happened to you causing the wires to short. Check the wire harness first is it is a quick and easy thing to do....
It was the harness under the seat. But we had that glued and taped (with fsk tape) But the very front where it goes through the fender came loose since there was no tape on that spot and what a mess. Didn't take long to fix just took a while to see that the mess was all the way on the front side of the fender. So removed it sodered it and reinstalled it and it won't be an issue anymore.
Make sure you put in the Dielectric Grease if you do not then your lights will not work properly. I changed my tail light to LED on 08 DWG and did not put in the grease, well lights would not work properly, so took it apart put in the grease and voila works perfectly.
Grease is not a cure-all for electrical problems, it is simply to keep moisture out of contacts. Personally I have never used it on any of my bikes, you should not need to if you have good solid connections.
GoOrdnance
03-12-2011 09:15 AM
