Is The Denim Paint Lacquerd
The paint is standard H-D Acrylic Lacquer of your color choice. It is then covered with the "Denim" satin Acrylic Lacquer clear coat. The clear coat can even be purchased in a spray can at the dealer and is extremely easy to spray. Never tried to pinstripe on it, but paint pin-striping should be no problem. If you use tape for striping, I imagine you would want the thinnest film possible so it adheres fully to the rough surface.
Thanks for that any other comments
Regards Brad
